speedbuggy67
i have a 96xp and as most know they don't have a tach what do you use for a tach since adapting a stock seadoo one isn't easy? I put new carbs on and obviously need a base rpm 3000 out of water and 1500 in water. what do you guys use and what do you suggest. i know some use a mini tach/hourmeter and saw others use a amazon.com tach.... i just want to do it right. IF drilling a hole for an oem tach is right them that fine but wiring with a resistor is needed if i read correctly. The less modifying i do the better unless OEM.
Scott
Scott
