red2blue
Cruising this mornin...all good....full fuel, E 68, L 73, 71mph+ @ 8100rpm through 6"-12" chop
All of a sudden, no warning, complete shut down. Won't turn over...no gauges...then gauges...beeps...no beeps....battery seems fine on the water....sc has just a tick of blade movement at intake...not hot.
"seadoo" shows on the dash occasionally after I put dess on post. Thing is though...it'll stay there after I remove the dess from the post...for a bit...never done that before.
Slight frying sound inside the hull....forward of the motor on the port side...doesn't last long enough the few times it's done it to get my ear close enough to pin point the location.
All that is what happens when I use my regularly used dess. When I try my stand by...I get full gauges and a maint flash...when I try to start...nuthin...lose all gauges....slight frying sound front port side of motor.
Any thoughts would be appreciated.
