wetbiker40
So I will give you as much info as I can about this ski. I think it needs a carb kit but you call it. I bought a 94 seadoo xp from a friends cousin and he said it ran great but had been sitting a year or so. So a friend and I went over there and got it running and I bought it. Took it out to the lake and it was starving for fuel so I went home and pulled the carbs with some friends and cleaned them. Stuck them back on and it fired up. Went to the lake to have a bolt fall into the motor. Pulled motor apart and fixed by a new rotary valve and retimed it. Took to the lake and got it on the water.. It would go great then slow down... then go really good then slowed down. Like a carb problem. THEN ANOTHER BOLT FELL IN MOTOR!!! :cuss: I just fixed it once again and took to the lake. but know its doing the same thing as the first time. Runs great on land then bogs down in water. If you spray so starting fluid in one of the carbs while in water, Its jumps up and wants to go so It must be the carbs. Where should I get a kit from and what kit? its the 657X motor. carbs are off now. maybe a better cleaning?
