WANTED - 97 GTX MPEM #278 001 200 or 278 001 242
If you have the broken one I might be able to fix them for you. Common problem with a surge protection diode blowing on these MPEM's when they are jump started. Does the 5 amp fuse blow? I have fixed a couple of these. I have access to an x-ray machine so I can locate the diode. I remove the potting material, replace the diode and re-pot the opening to keep mositure out
This is the first time I've heard of X-raying a seadoo part.
You must be in the medical field.... :)
Your problem does not sound like a typical blown MPEM problem. Or at least not a blown surge protection diode problem. When they go they short out the power going thru the 5 Amp fuse. It does sound like your beeper is kinda working and the 4 beeps/ticks is probably an error code of some sort. Might try researching what 4 beeps means on your machine
Maybe a problem with you key. Get your hands on a owners manual and look in the troubleshooting section to find what 4 beeps indicates
