adamhall83
hi guys, new here and new to the pwc world.
ive got a rxp 215(first pwc for me) thats been going well but took it out yesterday and after the 5th ride felt a vibration coming though the driveline and sound was slightly different sounding like the charger wasnt screaming as usual (i am very fussy with sounds and feeling so picked up on it very quick)
before i parked it up done a quick rpm and speed test and still get to 112kms no worries and rpm still hitting 8100.
water was pretty average but am well aware of shallow water ect but still took the bottom grid off and looked for objects caught in the prop but couldnt see anything except a peice of residual reed caught on the grid itself. took the intake off the charger thinking possibly the charger bearing or washer but the shaft is very tight and any movement i do get (1/6 turn maybe) is under full compression and need to squeeze 2 hands in to turn with the fingers as its too hard. took the plugs out and all 3 looked pretty good with white residue being visable assuming from clean high octane fuel and no oil at all. will do a compression test tonight as im anal as with things so want to be 100%, leads seem ok also. ive also checked the oil in the donk and there is no gunk or metal flecks nor is there alloy dust in the out hose on the charger. still starts and runs fine by the way, clean fuel, always fogged, flushed, and sprayed with inox after rides.
any advice would be great.
i do have a mechanic coming in a few days but i like doing things myself if i can to save a buck or 2 so if can diagnose the issue would be great. (ps the mechanic will be doing a service and full cheack at the least so im not out to cut the mechanic out all together, just dont wanna put his kids through college)
thanks guys
thanks guys
