TPS (throttle position sensors) 951 Di
Jonnyivy
Are the throttle position sensors on my 951 Di one of the more important parts for sending a signal to the MPEM to release more fuel into the injection rail ?
Does the fuel rate map according to the position of the TPS ?
I just replaced my MPEM and I read that you need to re-calibrate the TPS to the MPEM before it will send the correct fuel mapping to the injectors..
Thanks,
Jonny
Yes, they are a very important part of the fuel mapping and need to be calibrated.
You either need to take it to a dealer and have them reset to zero or buy a candoo pro. I bought one and it will tell you everything that is going on with your di. You won't be sorry you got it.
