2003 GTX-DI starting problems
ParamedicCurt
2003 Seadoo GTX-DI starting problems
When cranking with no throttle, it just cracks. If I hold the throttle at about 1/2-3/4 it sputters like it's about to start.
New top end. Good compression. The air compressor has been rebuilt. Good air pressure. Brand new QFS HFP-342DI fuel pump. Verified fuel pressure. I've gone through fuel, air and electrical with a fine tooth comb.
Are the throttle position sensors bad, or maybe they need to be reset by Can-doo Pro?
DAY YUM !!!! I never seen any that bad. Yikes. Absolutely must be corrected.
With all you've done and checked thus far when you fix these the ski should be GREAT !!!
