skewba98z28
I must be doing something wrong. With my xo and 85/88 nozzles I only run 57 at 7200.
Nah man you ski has to be going faster than that! You pulled hard on my last year when you got your water injection sorted out.
Well, isn't the 85/88 nozzle slightly larger than the stock nozzle? If so, the velocity of the water exiting would be a bit slower. This would allow you more holeshot, but less top-speed. 57 is still pretty damn good on this tiny little rocket sled![]()
Nice that stuff works wonders. I wasn't sure about it really working but ill have to get me some now haha.
Is it normal for the inside to look like this on my 96 xp and should I go ahead and replace stator while I have it open?
Yes, the 94XP is an X4 hull. A lot of guys don't consider it an X4 unless it has a 787. My opinion is if its an X4 hull it's an X4. This will probably start a new debate.
The 94XP is a good ski, 657x engine, 80HP I believe. If this is in good condition and a good price go for it.
Lou
Hell no thats not normal replace that flywheel stator trigger and check the starter if it was me I'd pull the front cover completely and change the front seal out. Wow thats pretty bad it there.
Sent from my C771 using Tapatalk 2
Ok so you think I need to replace the flywheel, stator, and idk what the trigger is? And is the seal you are talking about the one that seals the stator cover with 10mm bolts?
The trigger bolts just above the stator on the cover its what creates spark on a 787. the front crank seal needs to be replaced before running that ski any longer.
I have to support this statement, in fact, the 93 XP was an X-4, twin 657. Just a hair less output though, same setup as the 94, very hard to tell the difference in the 93-94. All of those X-4's were nimble, from 587, 657, 717 to 787.
Easy tell if a hull is an X4 is removable trim tabs... don't even have to get out the tape measure.
First post in this thread lists the history etc.
Other than race hull in 94... seadoo produced 95-96Xp, 96--99SPx with the X4 hull.
X4 hulls were produced with 717 and 787s
Not trying to be argumentative or fire up a debate, just my 2cents....
Sent from my Xoom using Tapatalk 2
