i read your thread in the candoo forum mine also resets a 3 degrees. ended up turning the idle screw back in to 9.4 degrees which idles 2300 rpm on trailer and should be in the ball park of 15 to 1700 rpm and will fine tune it once in the water after riding it for a while. so how is your ski running now? starting easy?
yes mine read -4.4 a couple time and think it was like you said timed out. i would log out of the program and log back in and hook the candoo up and read 3.0 again. i'm so glad i got the candoo so that i can do everything myself and not have to rely on the stealer.
Yes mine still does that. What I did was turn the screw in till I got to 4.2 and then reset at that area. It isn't perfect but it works. I think its a combo of a possible bad tps/ cable to tight/ screw to loose for me but it does the job. I think my problem is my tps screw is loose and turns much easier than most people say. So as it vibrates it might be unscrew a little and lower idle. My hard starts have been much better lately. Last week I went to lake no issues. I did have to give it a little gas to start but no cranking like I used to. Once it was on drove excellent. I plan on ultimately maybe replacing the tps and throttle body/ and or screw in the off season but for now no issues. When it reads -4.4 you don't have to log out just go to top and read vehicle again.
