its a cheap cornwell and is set a 20k . i tried the other settings and reads the same. yikes maybe im missing something. lol i know nothing about ohm meters. i will get another one tonight and recheck.
i tried them all same result. but will try it all again with the new meter i bought. thanks.Yep, start on the lowest scale and move up from there. I don't really care for the autorange meters that much b/c I prefer setting the range myself(less confusing for me) and usually I know which range to anticipate anyway.
yep i agree and as soon as i get back from the trip i will have time to ck on the rv for sure, out of time for now thanks. im only going to ride it for testing only this weekend.I would still be pulling the RV cover to make sure its the correct one & timed correct. Costs nothing to check it. just a little time & a few drops of locktite. From the looks of the RV chart that was posted, it looks like there were not many different valves used.
Who knows, maybe somebody times it for a carb'd ski, or worse yet timed it with the PTO piston at TDC instead of the MAG?
Again, I am thinking that SES has a process to eliminate a mistake like that, BUT, RV issues can cause your symptoms.
[MENTION=2932]sportster[/MENTION], do you have that PDF drawing of the printable timing wheel he can print out?
Found it! its still lurking in the forum.
http://www.seadooforum.com/attachment.php?attachmentid=1416&d=1235908614
wow he said the same to me on my rfi being 140 psi is perfect but others are pumping 150psi. WTH! thanks for the reply. not sure what to think now but you raise some good points on factory rotary valves as well as compression. i wonder if i should go a factory rotary??I really don't like the fact that he cuts his own rotary valves. What is wrong with OEM valves, do seadoo engineers really not know what they are doing?? Doubt it. I talked to him yesterday also, he told me 720 engines put out 140 psi stock and same with 787s and if they ran 150 compression that they would require race fuel or at minimum 91 or 93. I told him every one I have owned pumped out 150 psi and he seemed shocked at this revelation. Not trying to start a war, but these were my findings. I'm sending an engine to him for warranty work tomorrow.
i just talked to tom from ses and gave him the lowdown on how my ski has been running and he said he highly doubts that its a rotary issue but is ok to ck it if it would make me feel better. he seems to be very sure of himself. must have very strict quality control. i am also aware we are all human lol.he says he cuts his own rotary valves to be more precise timing that stock and Will be slightly different than factory specs. he told me to call him when i get the readings and he will help from there. just relaying how the conversation went. he said quite possibly a tps issue. told him had that reset. this is why i chose to be a under car tech lol!
yep im suspicious on the rotary valve too as makes his own timed differently. so i plan on buying an oem one.I'm quite sure I've read threads here about SES RV's not being setup correctly, I could be wrong though b/c often threads die out and honestly there's something about RV's that gives me shivers, no idea why, mine used to run so well but can't put a finger on my phobia.
Perhaps 140psi tends to hard start, hesitate and bog a bit using the Seadoo RV?
cant think of anything else it can be. ive combed it all with a fine tooth comb! at least i think i did. lol
