Johnny63
I bought a sportster 150 215scic last year and the performance was ok at best. i usually do a tear down and inspection of the driveline at the end of the season so I figured I would find some issues. First major issue was this boat had obviously sat for long periods of time in salt water. The reverse bucket bracket was corroded to the venturi nozzle and jet pump assembly. Finally after getting all that out I noticed the jet pump house was full of holes around the perimeter caused by corrosion. So I replaced everything with new parts which included:
bellows with bearings
carbon seal , hat and bellows
driveshaft
jet pump assembly
venturi
reverse bracket and bucket
impeller ( solas 14/19)
The boat struggles to get on plane, i swapped out the neoprene seal for a riva one thinking that might help, no luck. if I can get on plane it rides fine. the entire driveline is new. i cant figure it out, i had it apart multiple times looking for anything. I'm totally stumped.
driveshaft
jet pump assembly
venturi
