I have a 96 xp and I am having trouble diagnosing my problem. When go to start the ski all I get is a click from the solenoid and no crank so I figured I had a bad solenoid. I took off the started just to check it by directly hooking it up to the battery, it spins just fine (so it seems) off the ski ....but if i hook it up through the solenoid I can stop the gears with my hand. So why would directly hooking up the starter to a battery vs the solenoid produce such differences? I thought a solenoid just work or didnt work...is that not he case, could it not be pulling enough amps? or is my starter really going bad?
