Arriva2001
Thanks for all of the help. Yes, the carb, i believe, is fine. End of last season when I bought it, it was having a hard starting issue. So I took to a local mechanic and he took the carburetor off and cleaned it (i'm a little nervous about trying something like that myself...never have taken on anything that complex mechanically).
He suggested the replacement of the fuel lines to prevent future issues, so I did that over the winter. It ran really good the one time i used it this spring other than the surging I had reported...which seemed resolved after replacing that fuel line last weekend and removing that extra fuel filter. However, I went from that issue right into a no-starting issue. I've had an intermittent issue the past few times I used it where the starter would not engage on the first press of the button. But on the second or third time, it worked fine. So I am thinking this has been waiting to happen for awhile now... I do have a question though. I'm not really sure how to use a multimeter properly to test electronics. Any resource or youtube you could recommend? I have watched a few videos so far and I'm just not sure I'm following the general concept of how the multimeter tool helps you to understand how an electrical component is functioning/not functioning. I want to try to figure this out on my own...i'm pretty persistent... but could use a point in the right direction if possible.
