So here is the deal.. I completely blew out my port side pump, and bought this 95 XP pump on ebay a while back: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150308172887
I bolted on my prop, then bolted the pump on. Boat runs great. Here is my question... The wear rings are good in both pumps, and the impellers are about the same. The new impeller housing is metal, the old stock (starboard) one is plastic.
So, using the new port-side metal 95XP pump alone, I can get my boat on plane with just me in it, and hit about 30mph.
Using the starboard side plastic OEM pump alone, I cannot get on plane. With both pumps together I hit in the high 40's GPS speed. Is this normal?? Meaning is it normal that the OEM pump can't get the boat on plane? It seems the 95XP pump is more efficient. Both motors hit 7000rpm and run the same.
It does sound like the plastic pump side is cavitating a bit, it makes a different sound on full-throttle takeoff then the metal one... but, both pumps have a new foam seal, and the shoe looks fine on both sides... ? ? ? I am almost thinking of taking a video of it for you guys to check out... Both engines going the boat runs good.. It's almost making think to just buy the same used 95XP pump to have them "matched" if it pops up on ebay.
Any thoughts? I have the 1998 sportster 1800 with the twin 717's, 85HP a side.
