just took my 155 GTX 2013 out for a spin and 30 mins into use the following things happened;
- lots of engine Vibration
- Low power output
- Sounded like it was running roughly.
I put into reverse and it came right. After another 10 mins problems occurred again and I couldn't remedy by turning on / off, putting in reverse and playing with throttle.
I just purchased second hand. I've only done 7 hours (total 107) which has been awesome and I'm still learning about the mechanical aspects of my Jetski.
Its on a trailer on my drive way ... should I remove from trailer and inspect intake or is it likely to be my wear ring? (replaced at 100 hours).
Do these symptoms occur when intakes are blocked, or could it be something worse
Suggestions very much appreciated.
Geoff
- Low power output
Geoff
