A brief history of the ski:
My brother bought this ski roughly 4-5 years ago and other than oil changes no other maintenance has been done. It currently has just a hair over 200 hours on it. I'm going to take a stab in the dark and say that when it was bought it had maybe ~120 hours on it. I don't know much of the history of it and I have no idea if the SC has ever been rebuilt (though I highly doubt it).
Current Issue:
Took the ski out for the 2nd run of the year. It was running fine with no issues for the 1st hour. Around hour 2 we were cruising around 40mph and all of the sudden we lost a great deal of forward power. It's like someone just flipped a switch. There was also an audible vibration that increased in frequency and volume as the rpms increased. At idle, it sounded normal but as you gave it gas and the vibrations returned without an increase in forward thrust. We let it cool for an hour or so and started it back up. It ran fine for ~5min and the exact same symptoms returned.
I must apologize for my lack of knowledge about jet skis. While I am very mechanically inclined I just don't have a whole lot of experience in dealing with the mechanics of jet skis. I've tried searching this forum for my symptoms to try to determine the issue, but I've had no luck. Most searches turn up bad SC's (which seems very likely but nobody mentions vibrations with a bad SC, only no power). I've also come across no good wear ring conditions. This matches the vibration issue but I would think that this would be a slow progression that gradually gets worse, not a "light switch" problem.
We do a lot of river riding that is prone to sticks, trash, and just normal dirt (Ohio River). It's very possible that we sucked something in but at the time this problem reared it's head we were in clear water. Also, my dad added an unknown amount of "regular" oil (<1 L) prior to our trip unbeknownst to me.
My question is, what should I look at first? I'd like to at least check the simple things myself without having to take it to a service center and just say, "fix it".
Thanks for any advice, comments, or suggestions in advance!
Current Issue:
