Shop Discount Sea-Doo Parts
Single gauge hood conversion
Brprxt215
Messages
166
Location
Ny
Water Crafts
currently: 96 XP, 98 GSXLTD
Past skis:96spx,97spx,96xp,00rxdi,18GP1800,00GP1200, 96gsx, waveventure
I have just received a nice single gauge hood to put on my 96xp. I cut the two wire looms coming from the stock hood and into the hull. Now my beeper and stop start do not work anymore. There is still power to vts. Is the multi function gauge related to the beeper/stop start button? What wires would I need to reconnect in order to get power back and be able to start it again? I plan on only running the trim gauge on the new hood. The fuel float or fuse is bad so the multi function gauge is kind of pointless and the speedometer doesn’t work as usual. Any guidance would be greatly appreciated. Thank you!
suke
Messages
1,687
Location
Holly Springs, NC
Water Crafts
96 XP, 96 Wave Venture 700
I had the same issue when doing my conversion to single gauge hood. I ended up blowing the fuse in the mpem. Swapped it and all was fine. Give you say you have power may not be your issue.
Brprxt215
Messages
166
Location
Ny
Water Crafts
I should probably unhook the batterygood point lol. I haven’t tried hooking the wires back up yet. I just am unsure of the correlation of those wires to start stop switch.
Matt Braley
Premium Member
Premium Member
Messages
7,083
Location
Niceville, Fl
Water Crafts
I can't keep up with it anymore. I've got some really cool skis!!
The gauge power and signal wires are the only ones that run up in either hood. If your just running the VTS gauge then you need the power wire(purple), the ground(black), and the 2 browns(one brown, other brown with black stripe).
Brprxt215
Messages
166
Location
Ny
Water Crafts
Perfect thank you very much Matt! I will take a look and see how they are all connected in the stock hood. Do you by chance know if those wires all run to the vts gauge? Or would I have to hard wire them to intertwine?
Matt Braley
Premium Member
Premium Member
Messages
7,083
Location
Niceville, Fl
Water Crafts
Brprxt215
Messages
166
Location
Ny
Water Crafts
Awesome thank you Matt for the information I’m about to order the tool right now!
SPONSORED LINKS
Usergroup
