ChevySaintsMan
I borrowed a friends 96 gti and took it out on the lake. It ran perfectly fine for about an hour or so. Then all of a sudden it started to lose power and eventually started missing as if it was starving for gas. It had a full tank that I put in before I left. Before I used it. It had been sitting up for about a year with gas already in the tank. When I turned it off and let it sit for a while. I would start it again and take off for about 5 min no problems and the gradually it start losing power until it started sputtering again. Got it back to landing and was told I didn't put enough oil in the gas since it must be mixed because the oil injection unit was disconnect because of previous problems. So added more oil and went ran it again and got same results. Ride like the wind for a few moments and back to sputtering. Ok question is... Is it because of old gas? Is there a fuel filter that could be clogged and where is it? Or could not having enough oil been the reason for this? It's not knocking or ratteling as if anything is broken. Help please
