kashov
HI Guys I recently bought Jetski Seadoo RX DI, me and friends of main have been having a lot of fun for past few months. Most of the time we were pulling us on a wakeboard. One day I forgot to check the oil and while we was riding the jetski suddenly stopped...ok the oil tank was empty and we went out of the water (by telescopic paddle, I wear such a think because we ride on big a river).... got the jetski back home.Bought the oil on the next day and filled it into the oil tank then tried to start it ....it started without any problem.. everything was fine and we rode it few weeks.
Few weeks after that when I was riding the jetski, it started to lose a power then I immediately switched it off...but when I tried to start it again , it did not start. Went out of the water again and tried to start it for sereral hours but without any luck. What I understood here from the guys with the same jetski most of the problems on this engine are cased by the fuel pump but that is only what I saw here in the forum.
What we made today while were trying to fix it was: We screwed out the spark plugs and test them one by one if they made a spark, the result was that they made a very good spark..ok probably that was not the problem. Next thing we made was to check the fuel filter if the fuel is able to went through it ...the filter was ok (or I think so because I was able to blow through it.. ). Then we test the fuel pump if it worked ...ok it worked and pumped a fuel. I don't know if that pressure was enough to work well ,probably I have to find a way to measure it...
The strange thing was that the engine started 2-3 times today while we were trying to start it but when we released the accelerator the jetski switched off immediately I mean there were idle rpm's it just stopped. I think it looks like there is not enough fuel pressure to the injection which cause no fuel injected but I am not sure because I am not able to measure the pressure also there are bunch of things in this engine which might be broken...
I will be very thankful for any advice ....
P.S. I forgot to mention that I suspect the lanyard cap, sometimes I had to push it hard to start the engine otherwise it did not start, but that was rarely.
Thanks
Pavel
Thanks
Pavel
