Sea-Doo GTX 4-Tec has no power!
Reel Heel
I am currently trying to get my 2005 Sea-Doo running again. The battery is fully recharged, and has been tested, so I know that isn't the problem. All the relays and fuses seem to be in working order.
When I plug the key on the post, absolutely nothing happens. No power on the display, engine won't turn over, nothing.
Any points in the right direction would be strongly appreciated!!
Jump the solenoid to see if the engine cranks. If it does, it shows you have quality connections, good battery and a good starter as well as good wires.
If it does not crank, then we need to test for voltage at specific areas, we can get into that once you post your findings,,,
When I jumped the solenoid, the engine immediately turned over at a normal rate. So we now know the connections, battery, etc. are good.
My first guess is that something is going wrong with the kill switch but I could be mistaken.
