I have been using SBT (short block technologies) for several years. They have been around for over 10 years, providing a low cost service for us to buy cranks, pistons, sleeves, carb kits, wearing rings and of course, motors.
I have purchased 12 motors in the past 2 years. I have only had one with a problem and it was a broken RAVE bellows. All these motors are still running today.
I try and use www.seadoowarehouse.com for all my Seadoo part needs since it directly benefits our forum, helping us keep the lights on. But, there are something we do not sell.
I have had 2 members report they had a less than pleasurable experience with the sales and customer service department with SBT, so in all fairness, I want to open this thread for memebers who have used their service and tell us how your experience was. From waiting for parts a lot longer than they said would be here, motors that are delivered with problems that they seemed to try and blame on the purchaser or any other issues you might think is important that a prospective buyer might want to be aware of.
I have in the past, found that some of the problems that arise with these motors is not from a fault of theirs but from a lack of experience to put the motors in according to their specifications and running the break in oils to their requirements. Using the wrong injector oil (such as TCW-3) and not varying the throttles regularly. The most problematic things I've seen is after blowing a motor, say in the MAG piston, the same happens to the new motor. I would have to ask at this time, when the motor blew, did you go as far as to find the "root cause" as to why your old motor blew in the first place.
I had one member do a total upper end rebuild because his mag cylider bit the dust. I tried to warn him that if he didn't find our why it happened, just replacing the heads and pistons may lead to a second failure. On the second trip out, the mag cylinder failed again. It was finally determined that the crank main bearing at the MAG cylinder was bad.
So, take a minute, share your experience and vote on whether your experience was a good one or a bad one. Please take a minute to decide on whether the problem was from a lack of complete inspection of all your components that may have caused the failure or was it solely a issue with their quality of work.
SBT states that they do a 4 point check on all motors leaving the shop and that they only use OEM genuine replacment parts. They also state that their motor replacements are either one size overbore or standary. If you had problems and you believe they sent you a motor with 2nd bore over sizes, plese attach a pix of that size to your reply.......
I look forward to reading some of your reviews..........:cheers:
