1 1hsv1976 New Member Jan 2, 2012 #1 Should the impeller spin when you try to turn it with a screw driver easy or very hard
J JFizzleJR Premium Member Premium Member Jan 2, 2012 #2 1hsv1976 said: Should the impeller spin when you try to turn it with a screw driver easy or very hard Click to expand... Are you talking about the supercharger impeller or the jet pump impeller? The supercharger impeller should not turn by hand while installed in the engine. That more than likely means the supercharger clutch washers are toast.
