depami
Hello all
I'm new here and recently acquired a 2007 RXP 215 with ceramic washer syndrome.
I sent the SC to PWCM for rebuild and tore the engine down completely, except valves, to remove debris and ceramic sludge.
It got new ring gear, bearings, oil pumps and pressure relief.
It fired right up and runs great.
I've had it out three times, not quite an hour total, and each time it has let out a one second warning beep.
It happens on abrupt let off of throttle after full throttle run, 70 MPH @ 7850 RPM for 15-30 seconds.
It doesn't do it every time, only once per outing so far.
I have not checked oil pressure with a gauge.
Should I be concerned or is it normal for these to do this?
Thanks in advance,
Denny
Thanks in advance,
Denny
