I have an rxp 215 with the error code p0344. When you start it it runs erratically at first, but after 30 seconds it runs like it should. Of course I want to remove the error code. What did I do. On the ecm a5 and a19 checked for resistance, that gave 227 that is between the margins. What I want to do now is test the camshaft sensor itself for resistance. How do I do this? Should the sensor be on the block? Can it also be loose? There are 3 pins, on which pins can I measure the resistance?
Regards,
Richard
Regards,
Richard
