Rope stuck
Samcrawford9
I got my rope stuck and I’ve gotten all of it out but this little bit that’s jammed in the impeller doesn’t anyone have any suggestions on how to fix this?
Best to remove the pump as Ski-Doo says
You can then dress up your blades as one looks bent
get to your PTO and try turn engine backwards to remove rope
yep-pull that pump off. replace the ring and fix the impeller. it's actually not that bad of a job to do and the rings are cheap- maybe $75 on ebay. any outboard shop should be able to fix the impeller. once the nozzle is off, you'll be able to remove the cone and use an allen wrench to rotate the impeller backwards, then pull the pump off and fix it all up. I can do a ring & impeller swap in just over an hour now- gotten pretty good at it. I've sucked up a few ropes in my time! lol ;)
