It also helps if people have common sense in addition to common knowledge. I said that needle is closed and carb already runs rich. Why would I increase jet size if it is already too rich. If on the water I see lean conditions and it can not be remedied by opening needles less then 1-2 turns I will step-up the jets. How any more clear can I be. I can't care less what the piece of paper say. If conditions are rich, you do not up the jet.
As far as pop-off goes, I already explained, largely a misconception. Fuel is sucked by Venturi effect, low pressure is generated by moving air, not by vacuum.
But even if this is hard to digest... Softer spring is designed to get more gas into cylinders. If anything, I want LESS gas at the moment, not more.
It runs great, it runs slightly rich. Why the hell would I want to exaggerate slight imperfection that I have?
