johnnyfever
So when I went to winterize my 99 xpl it would not turn over. It was running fine last time it was used was 2 months ago. So I pulled the pump to make sure that wasn't the problem and still no movement. I tried to take starter off and broke off both bolts. So I'm thinking I will pull the engine and take a look. Any tips u guys would like to share on pulling engine and checking to see what seized up in the first place?
I already disconnected the pipe and removed the carbs
I think the next move is to remove the c clip on the drive shaft so I can pull shaft put amd just lift motor straight up.
Thanks In Advance for any help.
