Hello... I have a 96 GTX and the RAVE Valve in the front cylinder is stuck in there to the point I can't get it out. It wiggles around in the cylinder but won't pull out. Any suggestions?
I don't believe it came in contact with the piston. It runs OK with it stuck down and this happened while it was sitting over the last 4 weeks. Ran just fine before. What would cause that if it did?
The piece moves up about 1/16-1/8 inch then stops. it also wiggles from side to side just fine in the slot.
