To make a long story short, I purchased a 98 XP 951. It didnt run, found compression on PTO cylinder to be low (90psi). So I bought it just plaaning on putting a Top end in it and away I go. So anyhow I ripped it apart and found the pulse line that goes to the Rave valve solenoid laying in the bottom of the hull. I know I did not remove this line pulling it apart. So my question is, saying this line was off for a while when the previous owner had it running. Would that cause a lean condition (vaccuum leak) and cause it to burn up the cylinder? Just trying to narrow down the cause of the problem. The fuel lines have all been replaced a few years ago, along with the carbe being rebuilt. So I would assume it was safe to say its not a fuel delivery issue. I really dont want to have to go through the carbs again if not needed.
Thanks in advance!
Thanks in advance!
