I just read back through your thread and realized your plugs are wet with fuel, this is indicative of a very rich condition and probably your eyes are burning due to excess fuel as you stand next to the running ski. A too weak metering needle pop-off spring can cause this, as fuel control depends on the metering needle opening at the correct time, a weak spring advances this timing and opens the fuel chamber metering valve sooner, allowing the fuel to come on sooner.
If this is the case (that the carburetor is flooding the cylinders with fuel) then I must agree, the pop off is too low and the spring should be stronger. You also must have the correct size metering seat orifice diameter, the diameter is also a function of when the fuel metering needle pops open (pi*r^2*pressure) so either increasing the radius dimension of the metering seat orifice gives you a lower pop pressure as does reducing the spring pressure. If the needle pops open too easily then there will be more fuel in the intake.
BTW, it's the vacuum in the intake manifold that travels through the three sets of fuel ports and into the fuel chamber, which causes the round rubber metering diaphragm to move inward and push on the metering needle lever arm. As you already know, the metering needle must be off it's seat in order for fuel to enter the chamber. Thus the calibration of the carburetor is dependent on both the strength of the metering arm spring and the metering seat orifice size. Also important, is the geometry of the metering needle lever, sounds like you have it set correctly, flush with the fuel chamber bottom.
Many racers work diligently on this lever to manipulate it's geometry set up perfectly and minimize geometric inefficiencies.
Also, please use a high quality screwdriver of the correct size (usually #2 bit) that's not worn out and the tip flutes rounded over, to avoid damage to the screw heads. Somehow someone at the factory is great at getting them extremely tight. A bit of abrasive lapping compound or toothpaste on the screwdriver tip can help get a little extra bite that's sometimes needed.
