TrevorM
Yes, the pop-off gauge would work fine for that.
That’s good to hear! Would you know what fittings I would need? I think I just need a “T” 1/4” fitting. I could be wrong though.
You can just plug the return fitting on the carb and pump into the return hose.
As an added bonus, if you remove the plug from the PTO carb the pressure in the system will force fuel into the carbs and prime it for you. Once you see a little fuel come out the return fitting on the rear carb quickly put the return hose on it. The ski should fire almost instantly.
Keep in mind also that the pressure relief valve on the tank is set at about 3-4 psi so that s all you can pressure test to but a leak should show up at that.
A battery explosion would be no where near that big. That was fuel vapor ignited
I would recommend pump service and inspection. While it is off pull the cover plate off of the top of the carrier bearing support and inspect the drive shaft coupler adapter. At this age they start getting brittle and coming apart. If any sign of cracking, pieces missing, order two. There is one on the engine end of shaft too.
The impact screwdriver does work well. I have used it on these. Yes, 293 830 058. Is the part i was referring to. They are discontinued by the manufacturer, but there are aftermarket parts for these.
Its not that hard. I thought the same when mine disintegrated this year, pull the pump. Remove c-clip, pull shaft. The rest just comes apart. Put new pieces in and put back together.
The carbs are now fully rebuilt. I did notice the pop off for both carbs are around 43psi which according to seadoosource is 28-48 psi. I noticed
Curious, does your carbs have the accelerator pump? I've seen some with and without. A buddy I know with a 97 XP and his doesn't.
