psi exhaust water flow/ pls help
mark younggren
hey hi,
I need to know the PSI exhaust water flow on my 2000 challanger, dual rotax 85 horse engines? Got a small hole in one & need to repair. need to know the PSI water going thru to pick the right repair epoxy?? Pls help! did it with chit glue last time; have learned I need to know my psi water flow thru exhaust to use right epoxiy!:hurray:
Using epoxy is only a quick fix...bring the pipe to a welder to have it repaired correctly...I have seen members use JB weld for a temp fix rather then epoxy.
Karl
