Hello all,
This is my first post dealing with engine trouble.
I have bought a 1997 Speedster Jet Boat about 4 months ago. I have ran it about 7 times, mostly going well. I have had some cavitation problems but I expect that from older impellers and air getting into the jet drive from the hull. It runs about 50 on the water, much faster than I expected of it. The port engine was replaced early on, I spoke to all of the owners on the phone ( 3 of them).
The problem I am dealing with now is that the starboard engine is idling about 1k rpm and will not go any faster. Add some throttle and it dies. It would not even start till I started trouble shooting - I should add that that engine has had little by little increasing problems running out on the water. It would run
with little enthusiasm, till about 20 minutes into the ride - then it seemed to be fine. The time after that it would run poorly, taking longer till it ran stable. The last time out it ran poorly for about an hour - then it just quit working all together.
I have checked all the cylinders from the engines, and they read 120 ( i understand that 150 is ideal, but maybe it is just my compression tool). I swapped carbs from the 2 engines just to check that as a suspect. No difference. I even ran the fuel line from the port side to the starboard, that did nothing either. I should mention that the carb on the troubled engine seemed to spit out large amount of oil, kind of a back fire maybe.
I checked the pressure in the oil system to see if it was losing pressure ( it is using Walmart NMMA tc-w3. It has used that oil from when I picked up the boat.
I checked and swapped spark plugs, checked that they where getting electricity ( I do not know how to check the timing though).
I swapped batteries and looked over all the spark plugs, swapping them too. I don't think that it is the electrical system, but I should rule nothing out.
I do notice that when I removed the large purple muffler (that contains water in it) the rpm's go up. As well, if I put my hand over the rear exhaust the engine starts to die.
So this is where I am at, I do not know what to check next. Both engine start and run, but the starboard engine is still idling from 1k to maybe 2 k, and dies with throttle. I did add some lube to the PTO flywheel, but I didn't expect that to do anything.
If someone can help, much thanks in advance.
Nathan Harris
Nathan Harris
