I’m having the typical leaking oil injector tank issue and am frankly fed up with the poor design of the system and the amount of expensive API-TC oil it’s now wasted into the hull. I know the injector system is good on the 951 especially after redoing the hoses for it but enough is enough I’d rather go premix than spend more money on a new tank which is bound to leak again. Can I remove the tank without removing the internal pump as well? There is zero space to get in for a block off plate without removing the pipe, gas tank, or engine to do so.
