In my manual for my 2003:
- You get 2 beeps when inserting the key.
- You get 4 beeps after you stop the engine and that you leave the key in.
- You get a long beep when there is a problem.
Long beep after 2 beeps means in order to try (still according to the operator manual):
- Key is defective (try another key);
- DESS post is defective, replace DESS post;
- MPEM has a problem.
Do you hear a long beep at all?
When you replaced your DESS post, there were 4 wires to reconnect including a wire that makes a stop through the start/stop button (if it is like my 2003). Did you reconnect everything correctly? Also, my start/stop button is almost worn out and I am afraid it will be next in line. Is yours OK?
