2001 challenger 2000
Two weeks ago I took my boat out into the water. A few minutes into being on the water the boat lost all power and shut off. When I got it home, first thing I performed was a Compression Check. Cylinder 3 showed 0 (ZERO) compression.
I took off the cylinder cover and this is what I was looking at. Some pretty intensive pictures:
I believe the previous owner was not very good at maintaining the boat and some particle chipped off and damaged the piston/cylinder and cylinder cover. Hopefully thats it!
Now I am planning to swap out the piston and just wanted to get a little advice/help with the situation as to how I should go about swapping it out..
My original plan was to pull the motor and dissassemble it in my garage to replace the piston. At the same time that also causes some difficulty as to HOW to remove the motor from such a high position. A regular automotive engine lift will not reach that high. That being said is there a more simplistic way to do this while the motor is still in the boat?
Thanks in advance for all the help and assistance. I welcome all comments and suggestions.
-Alex
-Alex
