I have a 96 challenger with the 787. Still running the stock oiler. Will run all day long with no issues. Aside from some burbling around 2 or 3k rpm. Which is a pretty useless rpm on this boat anyway. But if it idles for more than 15 or 20 seconds when you go to take back off it will sputter and then eventually clear out and take off. The longer you idle the worse it is. It also does this on the first takeoff of the day. I know this and have been trying to avoid it by holding it above idle and giving random bursts of higher throttle. and it’s fine aside from sputtering when I take back off, although pretty annoying
But my girlfriend was piloting the boat with our friends on it the other day while o was riding our gtx and through the course of the day it fouled 2 plugs after idling. Thankfully I keep extra on it. They were all on the same cylinder, believe it was mag side but don’t remember for sure.
My first thought was crank seal but it’s strange to me that it will run fine all day long with no fouling as long as it’s above roughly 2000 rpm. So I was wondering if it may just be too rich on the fuel or even possibly the oil at idle.
