pisser
kass727
i was just wondering if anyone knew if it was possible to make the water shoot up out of the back of my jetski like it does on the yamaha's. like is there any way to rerout my return line so it shoots up instead of back out by the pump.
you can put an angle fitting there, or drill new hole at back on the bottom, and route it that way. Then when your tow'n someone, your spray'n them...:reddevil:
cool so would i use like a t joint tho nd keep the original exit aswell or should i just block that off and rout it someware completely different. also do u have any suggestions for what to use as a fitting after i drill the new hole
