Post some pics of the damage. I am in process of a major hull resto at the moment and I ended up using fiberglass resin with glass strands in it. Called "bondo glass" but the only thing it has in common with bondo is the name.
Alright... so If I understand properly... I sand... put the gel coat on... then resand & water buff?
Thanks. I've never done any kind of work like this, so I don't want to damage even more the ski![]()
yes, sand with 120 grit, apply gel coat patch, sand with 200, 400, 600, 800, 1000 grit then buff with a good buffing compound and a power buffer, then buff with scratch remover, then hand wax.
Would you guys recommend me any special buffer tool to do the job? I'm sure you guys don't recommend me to do the sanding by hand, unless I'm wrong.
