Hello everyone, I have extensively read through the posts and have not been able to find an exact match to what I need so here goes my question.
I have been paying a shop to winterize my 2 2001 GTX RFI and have happily paid the $180 for both without too much concern. But alas things have changed and while I am very good at most DIY I have always been paranoid to winterize these. I just want to be sure that I am doing the procedure correctly for my particular model and year pwc.
Well here is my plan:
Add stable to the gas and top off.
Purchase a pump (recommendations welcome), gallons of pink RV antifreeze and use a length of garden hose to hook to the hose connector at the rear of the pwc and the pump, start the pwc and then start the pump to pump the pink stuff into the pwc until at least 1 gallon goes thru and the pink stuff is spilling out from the back of the pwc, shutoff the pump shut off the pwc. This is the part I am most concerned with (paranoid). Is this all I need to do to protect the engine from freezing temps? Or is there another hose I need to be dealing with?
Remove the plugs and fog thoroughly crank the engine without the plugs to coat the cylinders, reinstall plugs.
Disconnect the battery and place on a trickle charge.
Am I good?? I know that the jet pump requires service also, but the shop has told me you can do that every other year. The pwcs have only been ridden about 15 hours this year..crappy Michigan weather.
Thank you for your help.
Tony
Tony
