(97 xp)I am trying to tune my carbs and need some help. I replaced the needle valves because they would not pop off anymore and set them both to within 1 psi of each other. Also the old pop off value was around 42 psi and the new is 37 psi; which is still within the manufactures recommended range. I never touched the idle or the high speed screw just the low speed screw. When I installed the carbs and started the ski it would not stay running (Take a look at the first video and you will see what I am talking about). Next I tightened the idle screw increasing the idle and adjusted the low speed screws. It is running now and if you take a look at the second video you will see what it sounds like .The RPM tool I am using is for 2/4 cycle and I am not sure if the readings are correct, but I hooked it up to another ski I have and used what its idle value was as a base line.
My questions are.
Since the pop off value changed is that what affected the idle and is that why It was dyeing until I increased the idle?
If you can tell from the 2nd video , does the engine sound like it is running ok or does it sound like I need to adjust some more?
When adjusting the low speed screws it is hard to tell when resistance begins, to be able to set them exactly the same so what I did was count how many turns it took before I reached what I thought was some resistance (3 full turns in) and then backed off according to the manufactures recommendations (1 full turn) I then turned the second screw in 2 turns to match the other ones 2 turns. My question is does this sound like a good way to do it?
1st VIDEO
http://www.youtube.com/watch?v=AoOxYD5vM4U
2ND VIDEO
http://www.youtube.com/watch?v=LTi4-pOPGV8
Thanks for all the help.
My questions are.
1st VIDEO
2ND VIDEO
