YUOnDaGround
What setup are you running, and why? Oil pump intact and functioning or dismantle and run premix fuel.
I switched to pre mix to avoid any probs on the merc 210 carb - runs great and no worries on problems for me![]()
I was worried about what path I should take. New boat (new to me) and I have to replace engine because of oil starvation according to the previous owner. The mechanic said that he replaced the oil lines after the fact and just tried to keep it running but he said there was too much damage. I just want to make sure everything is right. So I guess I'll just replace the lines (again), filters and pray.
Check the nipples going into the engine. If it was back firing, it could have cooked oil in them... and plugged them off. Also, change the filter.
If the engine is dead... do a pump test. It is outlined in the service manual. You basically spin the pump with a drill, and measure the output.
Finally... the mechanic says the it was oil starved. How does he know? Did he find something, or did he just take a guess??
Since you are putting in a new engine... I would drain all the oil from the tank, and refill it with an approved API-TC oil. A lot of people get cheap, and use TC-w3 outboard oil in their skis, and the engine just won't last on that oil.
Maybe I will do a write on how to change them and add pics. Its easy really.
Good to know, I was just going to top off the tank with synthetic and just use that from now on.
Ummm ... where are the oil filters?![]()
That's EXTREEMLY BAD !!!!!!!!!!!!!! If you don't know EXACTLY what oil is in the tank... you could wind up with a dead engine. 2-stroke oils don't mix well, and you could wind up with an oil tank that looks like it is full of Jello.
Just follow the hose off the bottom of the tank. There is 2 of them. They are like 11 bucks. When it warms up, I plan on doin a little how to write up on how to inspect the injection system and change the filters.
It is in the hose between the pump and the tank.
