Oil inside hull of jet ski
The best and easiest way to clean the hull is with Castrol Super Clean, I would dilute about 50%, elevate the ski, open the drain plug, spray it on, let sit 5-10 mins. and hose it down. Just use a garden hose, if you use a pressure washer you stand a risk of getting water into the electronics. It does a great job, your hull will look like new.
If you can't find the Castrol Super Clean, I've had good success with Purple Power also.
Lou
I usually dump in a bit of simple green, then add water, then mix it all about, then drain it out lol.
after 2-3x over a few seasons the inside is almost like new lol.
