Have had trouble in past with cylinders filling with oil, engine runs great.
Question- is the oil pump suppose to leak oil into the rotory valve area with engine off? Pumps oil ok when running. Alignment marks are aligned ok.
some people suggest inner crank seals bad, tore engine down and seals look and feel ok and snug. Rotory valve seal same.
Am I looking at the right area? Oil pump seeps oil when engine off, puddles in rotory valve area. The oil seem to come out of the injector port nozzels. I don't think it should but would appreciate a pros point of view. '
Thanks
Thanks
