I have a 240 Merc on an Islandia with a recurring problem. The small oil reservoir mounted on the port side of the engine apparently feeds via suction from the main 3 gallon oil reservoir. The engine mounted reservoir has an alarm which sounds when the level gets low. About 6 engine time hours ago, the small reservoir just stopped siphoning from the main tank setting off the dash alarm after about 20 minutes of run time (after I top it off manually). Any ideas on why the problem suddenly occured after many hours of trouble free cruising? It's getting old stopping every 20 minutes to top off the oil on a hot engine.
