J JohnMetta Member Aug 12, 2016 #1 Good morning and Happy Friday. I have a 2000 Seadoo GTI and I think my oil line is cracked and leaking. Attached is the part number. I believe it's 20. Is there anything I can use at a local hardware store to replace this? Attachments Untitled.jpg 10 KB · Views: 11 Untitled2.jpg 14.5 KB · Views: 7 Last edited by a moderator: Aug 12, 2016
mikidymac Moderator Staff member Moderator Aug 12, 2016 #2 I think some members found it but it is tygon line. Do not use the clear vinyl that Lows and Home Depot sells.
J JohnMetta Member Aug 12, 2016 #3 I was told to use the small 3/32" tygon line for the small 7" lines. Not sure about this larger 8mm tube though.
mikidymac Moderator Staff member Moderator Aug 12, 2016 #4 That is correct on the small ones. I think McMaster Carr sells the larger stuff and usually ships the same day.
J JohnMetta Member Aug 12, 2016 #5 I wonder if NAPPA has anything. Don't really have time to wait for shipping. Have to get this done this weekend.
mikidymac Moderator Staff member Moderator Aug 12, 2016 #6 You can use the vinyl in a pinch but it gets hard and cracks with time. For a weekend it will be fine.
mikidymac Moderator Staff member Moderator Aug 12, 2016 #8 Like I said originally you need tygon tubing but vinyl will work to get you through the weekend.
