They run better when they aren't hanging in the air!! (LOL)
There shouldn't be any reason to need to prime the lines. If everything is OK, then it will draw from the tank in just a few seconds. I'm guessing you have an air leak somewhere... or your fuel valve is bad.
I would start with putting a little suction on the feed hose, just to see if you can pull it up.
