IDoSeaDoo
didn't have time to read all the posts... you did check the ground to the coil right? I had a ski where that ground wire rotted on the inside and if you PRESS a voltmeter lead to it, it will make enough contact to read 12V, but when you let go, with no pressure, it reverts to 0V. I put a new ground wire on it, and it ran (until the bearings in the connecting rod exploded). Also, (I think) you can check for a positive pulse on the white coil wire with a voltmeter when you turn the pto by hand. This lets you know that the pickup coil is working.
