EDIT: I may have a 1997 model based off some pictures I've compared to online.
I am working on 1998 Challenger 1800 that I've had for awhile. I've run into several issues and will list
them.
Little history on the boat;
Sat for 3 years in a yard "kinda covered"
Sat with the engine cover/hood almost sealed (open about 1" at the front seal)
Both air intake covers removed
I bought the boat as I was told that it did run. However, after some testing today I can't imagine it has in awhile. I compression tested the starboard engine first and got 175psi on both cylinders and the engine sounds good while cranking. On the port engine, I got 180psi on the rear cylinder and the front locks the starter when trying to compression check. As well, there is a lot of milky material shooting from the front cylinder on the port engine while cranking. I'm a huge auto gearhead so this would typically mean water contamination to me. However, I wasn't sure if there is possible some water that leaked into the engine while it sat for so many years. I looked for a drain plug to drain the crank case but wasn't sure if this was possible. The port engine cranks slower as well but this has to be due to the milky debris.
Now, another issue. There is no spark on any of the engines which is why I imagine the boat was parked initially. The person that I got the boat from did give me a flash drive with the seadoo factory manual which I worked through today. We verified no spark by checking with new plugs installed into each plug wire and grounding the plug to the cylinder head(s) and visually checking for a spark/arc.
Did the following today;
Checked all fuses at the MPEM and behind the gauge cluster
While cranking the starboard engine, the Tach floats around 400rpm (not sure if that's normal)
Checked the main grounding area in the MPEM box in the engine compartment
Let me know what you guys/gals think. I'm on the fence about selling the boat as is.
Thanks
Matt
them.
Thanks
Matt
