bigtexan99
just a reminder, when you are blowing out the cylinders don't hold the starter for more than 20 or so seconds at a time, and let the starter cool between sessions. Also make sure your spark plug wires are grounded on the grounding posts or a fire could be started.
The milky stuff....sounds like oil mixed with a little water. Pour a little 2-stroke oil in a cup and add water to see. If you did ingest water into your engine it may be a little rusty in there. It might be worth the expense of a new gasket kit to open it up and clean it out.
There is a reservoir of oil in the counter balancer down by the crankshaft. Do a search on the forum to see where the 'fill' hole/bolt is for your engine. If you open the fill hole and stick a needle (kitchen gadget section of wal-mart) injection tool down the hole you can draw some fluid and see what it looks like.
